Use the following procedure to configure BFD on a Fabric Extend Tunnel.
    enable
    configure terminal
  2. Enable BFD:
    router bfd enable
  3. In the VLAN Interface Configuration mode, you can enable BFD:
    ip bfd enable
  4. In the Loopback Interface Configuration mode, you can enable BFD:
    ip bfd enable
  5. Enable BFD on an IS-IS Logical Interface:
    logical-intf isis <1–255> bfd enable
Enable BFD on a Fabric Extend tunnel:
Switch:1>enable
Switch:1#config terminal
Enter configuration commands, one per line.  End with CNTL/Z.
Switch:1(config)#router bfd enable
Switch:1(config)#interface loopback 1
Switch:1(config-if)#ip bfd enable
Switch:1(config-if)#logical-intf isis 1
Switch:1(config-isis-1-1.2.3.5)#bfd enable
